21324 Discussions
clock with GPS Syncronization (1PPS)
Hello!
Can i buid a clock circuit (1MHz) syncronized with the gps-module's PPS output ?
The PPS output have a 1Hz square wave.
regards
You can not use a PLL to generate the 1MHz signal from the 1 Hz square wave. You could implement a digital PLL to deliver exactly 1 million pulses for each PPS.
