Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
continuous assignment on port list fails
Had a module with an output tied high, e.g:module a(
output wire b = 1'b1);
Quartus 16.1 synthesizes to 1'b0. Is this to be expected by the LRM? I couldn't find anything explicit on the publicly available SV LRMs.
Of course, when I re-code it works as expected:module a(
output wire b);
assign b = 1'b1;
Thanks, sysTom
I'm not sure that is valid syntax in a port declaration (continuous assignment to a wire).
This should work:
module a(
output reg b = 1'b1);
I think the issue is not that: output wire b = 1'b1 should work, but rather it should throw an error.
You're right in that map does report
Warning (10034): Output port "b" at a.v(#) has no driver
When I change to reg type as you suggest it gets the same as I would suspect since a declaration assignment to a 'reg' type is not continuous - it's just an initial value.
It certainly works on ncsim - I can try lint, DC shell and modelsim to see if anybody else complains.
Thanks, sysTom
