Is it permissible to design custom RAM using megafunctions such as 41 bits, and 8 locations?
yes, but be aware of using ram in this way is likely to be quite wasteful,
Thank you much for your reply. I tried to set up a 2-port RAM 41 bits X 8, but it seems the options are alway to the power of 2 to choose num. of bits. any suggestions Tricky?
Just leave some of the bits unconnected?
Or create 5x 8 bit rams, and 1x1bit ram.- Mark as New
I 'll probably leave bits unconnected as you suggested, thank you.
