21611 Discussions
declaring multiple packed array dimensions is a SystemVerilog feature.
cause: Error (10839): Verilog HDL error ***: declaring multiple packed array dimensions is a SystemVerilog feature.
description: 1. When I build a project with Quartus II version 14.1, there accurs the above problem.
Then I select "SystemVerilog" in Settings->Copiler Settings->Verilog version in Quartus II, the problem remains.
2. How should I solve this problem without modifying the codes?
Must I use synplify to generate .vqm?
