hi,
i have done a vhdl project with quartus and call it with nios, I don't have good result do to a delay generation. please how can i repair my work and have this result after this delay?? thank youLink Copied
Your problem description isn't very clear. If your VHDL component needs some time to process a request, you can have a status register with a "busy" or a "done" flag to tell the software to wait.
Hi Daixiwen,
can you tell me how to add this register?? If you have an example it will be wonderful and thank you very match.- Mark as New
It depends on how you made your component. Show us your code and it will be easier to help you.
ok this is my code:
ENTITY comp IS PORT ( a : IN STD_LOGIC_VECTOR (31 DOWNTO 0); result : OUT STD_LOGIC ); END comp ; ARCHITECTURE SYN OF comp IS begin process (a) begin if a=25 then result <= '1'; else result <= '0'; end if; end process; END SYN;- Mark as New
okay, now what do you want to do and where do you need to have a delay?
Topic Options
