Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
delay generation problem
hi,
i have done a vhdl project with quartus and call it with nios,
I don't have good result do to a delay generation.
please how can i repair my work and have this result after this delay??
thank you
Highlighted
Your problem description isn't very clear. If your VHDL component needs some time to process a request, you can have a status register with a "busy" or a "done" flag to tell the software to wait.
Highlighted
Hi Daixiwen,
can you tell me how to add this register?? If you have an example it will be wonderful and thank you very match.
Highlighted
It depends on how you made your component. Show us your code and it will be easier to help you.
Highlighted
ok this is my code:
ENTITY comp IS
PORT
a : IN STD_LOGIC_VECTOR (31 DOWNTO 0);
result : OUT STD_LOGIC
END comp ;
ARCHITECTURE SYN OF comp IS
begin
process (a)
begin
if a=25 then result <= '1';
else result <= '0';
end if;
end process;
END SYN;
Highlighted
okay, now what do you want to do and where do you need to have a delay?
