21611 Discussions
device programming failure
G_ISAAC
when I run Signal tap analyser, the FPGA is recognized, the compilation is done without any error, but 8 times out of 10 when I program the FPGA "programm device" the peripheral disappears and it is marked "no device is selected" with the following error "Error (209015): Can't configure device. Expected JTAG ID code 0x031050DD for device 1, but found JTAG ID code 0x00000000. Make sure the location of the target device on the circuit board matches the device's location in the device chain in the Chain Description File (.cdf)."
i use a MAX10 10M50DAF484C6GES
Fakhrul
Hi G_ISAAC,
Sorry I missed your post. May I know what version of Quartus you are using?
Fakhrul
Fakhrul
As we do not receive any response from you to the previous notification that we provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
