Programmable Devices
20703 Discussions
downloading program to FPGA
Hello everyone,
I think I have some problem to downloading my program to FPGA.
I've checked in device manager, I could recognize the both FPGA in my system.
I've asked already the VHDL program in forum, seems it doesn"t have problem, thus I've checked I assigned the right pin.
In programmer, I've succeed to downloading the program, progress successful, also when I press start in programmer, I have reaction of LED in USB-blaster II, its LED switch to green, then switch back to blue and on the same time, I could noticed a voltage jump in pin TDI and TCK(clock).
I've also changed the frequency of Jtag from 24MHz to 6MHz.
When I downloading the program, it should switch down a LED.
Power supplier of 3.3V LED FPGA. So my program to put one pin in the mass
library ieee;
use ieee.std_logic_1164.all;
ENTITY TP2LE IS
PORT(
s : out std_logic );
END TP2LE ;
ARCHITECTURE data_flow OF TP2LE IS
BEGIN
s<= '0';
END data_flow;
This is my program FPGA
Then in schematic the compnent TP2LE is directly connected to pin J2
and I use an Altera max 10
Could anyone help me
Thank you very much
Have you seen if it makes a difference setting s to '1'?
it might be easier to debug putting a counter in there to make an LED flash, rather than just try and turn it on. Then at least you'll know the design is loaded
--- Quote Start ---
--- Quote End ---
Thank you for your replying
Yes, Ive checked to set 1, but it still doesn't work and Everything were already solder in the board by my predecessor, so I couldn't modify the circuit anymore
