Hi. I am making digital clock, and I have problem..
When i insert the red letters, errors rise. ( when I remove the red letters, errors is removed. error : Error (10028): Can't resolve multiple constant drivers for net "hour_2p[x]" at counter_test01.vhd Error (10028): Can't resolve multiple constant drivers for net "minute_2p[x]" at counter_test01.vhd Error (10028): Can't resolve multiple constant drivers for net "second_2p[x]" at counter_test01.vhd what does " cant't resolve multiple constant drivers for net ~ " mean? How can I remove the errors? LIBRARY IEEE; USE IEEE.STD_LOGIC_1164.ALL; USE IEEE.STD_LOGIC_UNSIGNED.ALL; ENTITY counter_test01 is port( button0 : in std_logic; -- mode_change button2 : in std_logic; -- time_select_up_key, and select_key button1 : in std_logic; -- time_select_down_key sw9 : in std_logic; -- select_key seven_seg0 : out std_logic_vector (7 downto 0); seven_seg1 : out std_logic_vector (7 downto 0); hour_2p : out std_logic_vector(5 downto 0); -- hour minute_2p : out std_logic_vector(5 downto 0); -- minute second_2p : out std_logic_vector(5 downto 0); -- second rst_n : buffer std_logic; --active_low_reset clk : in std_Logic); --clock_pulse end counter_test01; ARCHITECTURE arc of counter_test01 is signal clock_count : std_logic_vector(3 downto 0); signal second_pulse : std_logic; signal minute_pulse: std_logic; signal second_count : std_Logic_vector(5 downto 0); signal minute_count : std_logic_vector(5 downto 0); signal hour_count : std_logic_vector(5 downto 0); signal button0_sg : std_logic_vector(2 downto 0); signal button1_sg : std_logic; signal button2_sg : std_Logic; constant clock_cnt : integer := 9; -- 10Hz to 1Hz constant second_cnt : integer := 59; constant minute_cnt : integer := 59; constant hour_cnt : integer := 23; constant zero : integer :=0; constant six : integer :=6; begin process(rst_n,button0,sw9) begin if(rst_n ='0') then button0_sg <= (others =>'0'); button1_sg <= '0'; button2_sg <= '0'; elsif(button0'event and button0 = '1') then if(button0_sg < six) then button0_sg <= button0_sg + 1; end if; end if; end process; process(rst_n,clk) begin if(rst_n ='0') then clock_count <= (others =>'0'); second_pulse <= '0'; elsif(clk'event and clk ='1') then if clock_count < clock_cnt then clock_count<= clock_count + 1; else clock_count<= (others => '0'); end if; if clock_count = clock_cnt then second_pulse <='1'; else second_pulse <= '0'; end if; end if; end process; process(rst_n,clk) begin if(rst_n ='0') then second_count <= (others => '0'); minute_pulse <= '0'; second_2p <= (others => '0'); elsif(clk'event and clk = '1') then if (second_pulse = '1') then if second_count < second_cnt then second_count <= second_count + 1; else second_count <= (others => '0'); end if; end if; end if; end process; process(rst_n,clk) begin if(rst_n ='0') then minute_count <= (others => '0'); minute_2p <= (others => '0'); elsif(clk'event and clk = '1') then if (second_count = second_cnt and second_pulse = '1') then if minute_count < minute_cnt then minute_count <= minute_count + 1; else minute_count <= (others => '0'); end if; end if; end if; end process; process(rst_n,clk) begin if(rst_n ='0') then hour_count <= (others => '0'); hour_2p <= (others => '0'); elsif(clk'event and clk = '1') then if (second_pulse = '1' and second_count = second_cnt and minute_count= minute_cnt) then if hour_count < hour_cnt then hour_count <= hour_count + 1; else hour_count <= (others => '0'); end if; if hour_count = hour_cnt then rst_n<= '0'; end if; end if; end if; end process; ------------------------------------------------------------- ------------------------------------------------------------- time 24LIBRARY IEEE; process(rst_n) begin if(button0_sg = "000") then second_2p <= second_count; minute_2p <= minute_count; hour_2p <= hour_count; end if; end process; end arc;Link Copied
I can see your hour_2p, minute_2p ... also assigned in reset of previous process. So just remove them from there and reset them in their last process.
And to complete kaz' answer, "cant't resolve multiple constant drivers for net" means that you are assigning a value to the same signal in different places, either from several processes (which is the case here), from several concurrent statements in the architecture, or a combination of both. While this is valid in VHDL, it isn't synthesizable.
