21604 Discussions
error compilation
hello
I use the Quartus II V 7.2, I have a Statix II, and when i would compile my design, i receive the message:
Error (10003): Can't open encrypted VHDL or Verilog HDL file "C:/CAO/cpu.vhd" -- current license file does not contain a valid license for encrypted file
Error: Node instance "the_cpu" instantiates undefined entity "cpu"
Error: Quartus II Analysis & Synthesis was unsuccessful. 2 errors, 10 warnings
Info: Allocated 169 megabytes of memory during processing
Error: Processing ended: Tue Apr 01 10:18:08 2008
Error: Elapsed time: 00:00:07
Error: Quartus II Full Compilation was unsuccessful. 2 errors, 10 warnings.
please help me if its possible
thanks
Make sure your license is active and encrypted NIOS II license is included, look at license setup in Quartus II 7.2.
Ketan
hi Ketan,
thank you for your reply,
I arrived to resolve this problem, it was because of the licence which was not good, I changed it, that works.
thanks
