error in quartus
Hey guys! :)
when i run the code from https://www.altera.com/support/support-resources/design-examples/intellectual-property/embedded/nios... in quartus 13.0sp1 and i got error and shown below. im using de1-soc board for my project.
please help me:(
Error (12006): Node instance "eth_std_main_system_inst" instantiates undefined entity "eth_std_main_system"
Error: Quartus II 64-Bit Analysis & Synthesis was unsuccessful. 1 error, 3 warnings
Error: Peak virtual memory: 593 megabytes
Error: Processing ended: Fri Apr 28 17:23:26 2017
Error: Elapsed time: 00:00:14
Error: Total CPU time (on all processors): 00:00:10
Error (293001): Quartus II Full Compilation was unsuccessful. 3 errors, 3 warnings
Readme says
--- Quote Start ---
To build the system, you will need to generate the system in SOPC Builder and compile the design in Quartus.
--- Quote End ---
You apparently skipped the first step.
