20252 Discussions
file path problem while using jupyterlab
Wei-Chih
Hello intel oneapi devcloud team
I have a question about file path while using jupyterlab as below description and picture:
In my .cpp file, I need to use the data .in that exist in a file, so I define something as a path (for example:  #define DATA_DIR "C:/Users/user/Desktop/TRYONECPP/data/bm1"). It can run when i use visual studio in my local system.
Then, I wanna run it on jupyter cause I have to try cpu, gup and fpga, So I change the path define to #define DATA_DIR "TRYONECPP20220705/data/bm1". It will run fail when I perform it by qsub as below
Do you know how to write the correct path if i want to read data from u136316@s001-n012:~/TRYONECPP20220705/data/bm1.
file path and cpp code as below. How to modify the path in my .cpp code?
data in the bm1 file
hareesh
Hi Wei-Chih,
did you try giving entire path from root directory.
can you please share more details of code how you are calling that file and complete path of TRYONECPP20220705.
thank you.
Wei-Chih
