fopen and fclose
hi,
can i use fopen and fclose in niosII ide?
is'it possible to read and write from a file in the hard disk?
or should i program the flash after that read and write from the flash memory?
how can i read and write from the flash memory?:eek::eek::eek:
yes
it depends on if your system has a hard disk?
and I'm guessing it doesn't
I think this way is first step for you.
> how can i read and write from the flash memory?http://www.alteraforum.com/images/smilies/eek.gif http://www.alteraforum.com/images/smilies/eek.gif http://www.alteraforum.com/images/smilies/eek.gif
in basic way, you have to access devices via address.
if you want file-system, you have to create file-system some how.
there is several way like Linux/uC-OSII...
you can create file-system by your self(it's difficult)
so, if you are new to NiosII.
you can read and write data via UART(RS-232C) , JTAG, SPI, I2C...
