21604 Discussions
generate jbc file with command line
WShih8
my condition is multi CPLD with a daisy chain mode.
and all CPLD is Max10 10M04SA
I have to try to generate jbc by quartus_cpf with multi-devices via the cdf file.
And the command line is:
quartus_cpf -c DaisyChain.cdf Programming.jbc -o background_programming=on
follow the Max10 configuration user guide and Quartus II script reference guide.
but in multi-chip daisy chain mode, I cannot DO_with_ISP mode successfully.
somebody knows how to gen the jbc file with DO_with_ISP.
my CPLD is Max10 10M04SAU324, Quartus programmer is 20.1
NurAiman_M_Intel
Any error message shown?
Can you try to program with the latest Quartus version such as version 22.1 or 22.2?
Aiman
WShih8
Upload the example pof_cdf.zip for you to reference.
You can view the comparison results.
Thru Programmer v18.1.0625 and v20.1.1.720 to generate JBC of around 249,205 bytes (~243KB), the CRC checksum is different.
But if I try to use the command line "quartus_cpf.exe" to create JBC, the file size is up to 552,296byte (~539KB).
And the file cannot use a USB dongle or Linux system to update the CPLD firmware.
If I try to update CPLD firmware, my CPLD will immediately go down, and the daisy chain will crash directly.
the command line is: (quartus_cpf.exe CDF_filename/pof_filename Output_JBC_filename -o background_programming=on)
quartus_cpf CDF_10M04SAU324.cdf Output.jbc -o background_programming=on
-o background_programming=on >> this is for Max10 ISP function enable option.
WShih8
Hi Aiman,
The return messages are an illegal option.
Quartus lite version only update to v21.1
NurAiman_M_Intel
We noticed that you have request support from Intel Premier Support(IPS) account. Our team will continue to provide support from IPS and proceed to close this forum thread.
Thank you.
Aiman
