21615 Discussions
generate .jic file from .sof and .elf
ScottShin
I'm trying to generate .jic file from .sof and .elf that use Terasic's self-balancing car demo_nios_code practice. All .sof and .elf  are not modified, but my .jic can't work like demo_batch_jic's .jic file. The programmer was also successful in my practice.
(tool: Quartus lite18.1 host PC: WIN10 Board: DE10-Nano)
I follow step like below:
1.turn .sof and .elf to .flash by instruction:
sof2flash --input=DE10_Nano_Bal.sof --output=hwimage.flash --epcs --verbose
elf2flash --input=DE10_Nano_bal.elf --output=swimage.flash --epcs --after=hwimage.flash --verbose
2.turn both .flash to .hex by instruction:
nios2-elf-objcopy -I srec -O ihex hwimage.flash hwimage.hex
nios2-elf-objcopy -I srec -O ihex swimage.flash swimage.hex
3.open "convert programming file" GUI configure like the attached picture:
Hope anyone can give me some advice, I will appreciate it.
(I also attach my program file. it wasn't modified.)
JohnT_Intel
From the jic generation, I observed that you do not set the address for the hex file. I would recommend to set the address that you used based on your Quartus design.
JohnT_Intel
I wouldn't recommend converting the sof -> flash -> hex -> jic.
You should convert the nios II FW code to hex and when you are converting to JIC file then you can include both sof and the Nios II FW.
Please refer to https://www.intel.co.jp/content/dam/altera-www/global/en_US/kdb/rd11122013_865/nios-ii-boot-from-epcq-and-epcs-in-quartus-ii-13_0.pdf.
ScottShin
Hi sorry took it took long to reply to you.
I trying the way by the document. Added legacy_epcs_flash_controller in the Qsys, I also set Nios's  reset_vector in epcs_flash_controller. then I convert the program file to .jic.
I program successfully, but my function didn't work. seem like Nios doesn't boot right.
That is my memory file.
Meanwhile, I also try the Nios2 flash programmer, but GUI has a problem that can't read the Epcs layout patch file. So I type instruction to implement the flash programmer in Nios2 commend shell , then I got information after both flash programmer instruction finish.
flash programmer instruction :
#sof transfer to flash
sof2flash --input="output_files/balcar_nios.sof" --output="software/balcar_soft_bsp/flash/balcar_nios_epcs_flash_controller_0.flash" --epcs
#program sof flash
nios2-flash-programmer "software/balcar_soft_bsp/flash/balcar_nios_epcs_flash_controller_0.flash" --base=0x1101000 --epcs --sidp=0x11020B0 --id=0x0 --timestamp=1603266025 --device=2 --instance=0 '--cable=DE-SoC on localhost [USB-1]' --program --erase-all --override=c:/nios2-flash-override.txt
#elf transfer to flash
elf2flash --input="software/balcar_soft/balcar_soft.elf" --output="software/balcar_soft_bsp/flash/balcar_soft_epcs_flash_controller_0.flash" --epcs --after="software/balcar_soft_bsp/flash/balcar_nios_epcs_flash_controller_0.flash"
#program elf.flash
nios2-flash-programmer "software/balcar_soft_bsp/flash/balcar_soft_epcs_flash_controller_0.flash" --base=0x1101000 --epcs --sidp=0x11020B0 --id=0x0 --timestamp=1603266025 --device=2 --instance=0 '--cable=DE-SoC on localhost [USB-1]' --program --override=c:/nios2-flash-override.txt
result information:
program sof.flash result 
program elf.flash result 
Any advice, I will appreciate.
JohnT_Intel
ScottShin
Thanks, I solve the problem. although at first, it jumps out massage "exceed flash memory", but I change  SOF's property to compression.
JohnT_Intel
Glad that you are able to resolved the issue. Feel free to file new forum if you have any other queries.
