Is it possible to generate the .sof file if the source code and constraints file are the same and using the same Quartus version?
I have an archive of source code and .sof file but would like to re-generate all the reports for Power analysis and floorplanner.Link Copied
Update: I was able to use same version of Quartus and Pin assignm. to get an exact same output binary file.
