How to generate .hex programming file from Quartus Prime software?Thank you in advance.
You can convert the design output SOF/POF to Intel Hex file format via the Convert Programming File option. From the "File" menu, choose the "Convert Programming File" option. Here select the type of format you want from the drop down list and provide the input file to convert. The tool will convert the file to HEX format.
--- Quote Start --- How to generate .hex programming file from Quartus Prime software?Thank you in advance. --- Quote End --- Thank you for the quick response
Topic Options
