help needed!!!
I am trying to do my assignment, I got this error in my port map
Error (10500): VHDL syntax error at FA.vhd(34) near text "port"; expecting "(", or "'", or "." Error (10500): VHDL syntax error at babi3.vhd(38) near text ")"; expecting "<="this my program...the error is in my port map???
I am newbie in Quartus...help me plz...:confused::confused::confused::confused:
library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; use ieee.std_logic_arith.all; entity DU is port( clk,rst : in std_logic; dataA,dataB : in std_logic_vector(31 downto 0); Psel,Qsel,Rsel,Tsel : in std_logic_vector(1 downto 0); Use1,Wsel : in std_logic_vector(2 downto 0); ldA,ldB,ldE1,ldE2,ldM1,ldM2,ctrlM1,ctrlM2,ldP,ldQ: in std_logic; A_tp,B_tp : out std_logic_vector(31 downto 0); E1_tp,E2_tp,P,eq,lt : out std_logic_vector(7 downto 0); M1_tp,M2_tp,Q : out std_logic_vector(21 downto 0) ); end DU; architecture DU_arch of DU is signal Ain,Bin :std_logic_vector(31 downto 0); signal E1in,E2in :std_logic_vector(7 downto 0); signal M1in,M2in :std_logic_vector(21 downto 0); signal zero1 :std_logic; signal Pin :std_logic_vector(7 downto 0); signal Qin :std_logic_vector(21 downto 0); component RegE1 port( d : in std_logic_vector(7 downto 0); en,clk,rst : in std_logic; q : buffer std_logic_vector(7 downto 0)); end component; component RegE2 port( d : in std_logic_vector(7 downto 0); en,clk,rst : in std_logic; q : buffer std_logic_vector(7 downto 0)); end component; component RegA port( d : in std_logic_vector(31 downto 0); en,clk,rst : in std_logic; q : buffer std_logic_vector(31 downto 0)); end component; component RegB port( d : in std_logic_vector(31 downto 0); en,clk,rst : in std_logic; q : buffer std_logic_vector(31 downto 0)); end component; component RegM1 port( d : in std_logic_vector(21 downto 0); ldsh,en,w,clk,rst : in std_logic; q : buffer std_logic_vector(21 downto 0)); end component; component RegM2 port( d : in std_logic_vector(21 downto 0); ldsh,en,w,clk,rst : in std_logic; q : buffer std_logic_vector(21 downto 0)); end component; begin zero1 <= '0'; RegA port map( dataA,ldA,clk,rst,Ain); RegB port map( dataB,ldB,clk,rst,Bin); RegE1 port map( E1in,ldE1,clk,rst,E1_out); RegE2 port map( E2in,ldE1,clk,rst,E2_out); RegM1 port map( M1in,ctrlM1,ldM1,zero1,clk,rst,M1_out); RegM2 port map( M2in,ctrlM1,ldM1,zero1,clk,rst,M2_out); RegP port map( Pin,ldP,clk,rst,P); RegQ port map( Qin,ldQ,zclk,rst,Q);
try component RegE1 is port(and do the same for all your component declarations.
The is keyword in component declaration is optional. As said, the error is in component instantiation. It simply misses instance names.
regainst: RegA port map( dataA,ldA,clk,rst,Ain);
--- Quote Start ---
--- Quote End ---
Istance names missing is one of the errors. Ports declaration are also needed to be added. The fellowing information is I got after adding instance names. I think checking several times after constructing programme could greatly avoid those errors.
** Error: E:/modelsim_prog/du.vhd(69): (vcom-1136) Unknown identifier "e1_out". ** Error: E:/modelsim_prog/du.vhd(70): (vcom-1136) Unknown identifier "e2_out". ** Error: E:/modelsim_prog/du.vhd(71): (vcom-1136) Unknown identifier "m1_out". ** Error: E:/modelsim_prog/du.vhd(72): (vcom-1136) Unknown identifier "m2_out".Good Luck!
Salming
