help with SDRAM
Hello
I need to load my code on SDRAM and run it but I don't know how to do it exactly (I already defined SDRAM on qsys) !! :(
Help me with a clear tuto or doc about that ?!
PS: using quartus 13.0 as well as nios ii web edition
much appreciated !
If you already have the sdram controller in your Nios-Qsys system, you simply need to link your code into sdram.
Open the bsp properties and set it in the linker options.
