20751 Discussions
how to estimate whole power in codesign application
hi!
I use the Quartus II 6.1 in my work
Ineed to estimate the power of a program implanting on the FPGA (Altera Startix)
my projet was composed on two parts (software and hardward) so I need the power of tow parts of projet
when using " poweranalyser tool"in the quartus II I estimate only hardware part
what can I do?
thank you
Do you mean the software part is a code for a processor like NIOS II? The synthesis and fitting tool gives you the LUT, I/O and memory consumption of each of your design modules. You can find out the consumption of resources by the processor/microcontroller from the compilation report, feed it in the power calculator and find out the power consumption.
