21335 Discussions
how to resolve JTAG problem
Hello, I am using USB-Blaster to connect to the board.
I am trying to run a sample program from DEVKIT v1.0.1 on EMIF.
It is said on the website that this example should work with my EP2C70 family(this is what I have), but the example, when I want to program it onto my board under "Device" field says: EP2C35.
This results in the following error:
"Error: Can't configure device. Expected JTAG ID code 0x020B40DD for device 1, but found JTAG ID code 0x020B60DD."
Is there a way to resolve this problem?
Thank you very much
Problem is resolved
You might want to tell others how you did it.
Sorry, did not realize.
So, all I have done is: switched the "Device" in the settings window to the device I needed and recompiled for the proper Top-Level entry.
It resulted in a proper .sof file for the needed device and was further on programmed on the hardware.
Simple... I am just totally new in this busnees :)
