19984 Discussions
hps boot fails with Quartus prime pro 18.1
Rk_Athram
we are using stratix 10 GX dev kit and quartus prime pro 18.1
ISSUE: HPS ddr4 is not booting
       DDR4 is detecting but DDR4 clear failed
                              ddr4 calibration failed
we selected FPGA Configuration first method.
have downloaded example design from https://releases.rocketboards.org/release/2020.05/gsrd/s10_gsrd/
compared the project and found change is qsf for the pins
"set_global_assignment -name USE_PWRMGT_SCL SDM_IO0
set_global_assignment -name USE_PWRMGT_SDA SDM_IO16
set_global_assignment -name USE_HPS_COLD_RESET SDM_IO12"
Assignments ➤ Device ➤ Device and Pin Options ➤
Configuration Pin Options.
tried to change pins according to tool is not accepting the change(please see the attached snapshot)
other than this there is no change!
  Teraterm log:
U-Boot SPL 2019.10-02883-ga2f8989-dirty (Aug 15 2020 - 15:14:38 +0530)
Reset state: Cold
MPU         1350000 kHz
L3 main     385714 kHz
Main VCO    2700000 kHz
Per VCO     2000000 kHz
EOSC1       25000 kHz
HPS MMC     48214 kHz
UART        96428 kHz
DDR: 4096 MiB
SDRAM-ECC: Initialized success with 896 ms
QSPI: Reference clock at 400000000 Hz
WDT:   Not found!
Trying to boot from MMC1
U-Boot 2019.10-02883-ga2f8989-dirty (Aug 15 2020 - 15:14:38 +0530)socfpga_stratix10
CPU:   Intel FPGA SoCFPGA Platform (ARMv8 64bit Cortex-A53)
Model: SoCFPGA Stratix 10 SoCDK
DRAM:  4 GiB
"Synchronous Abort" handler, esr 0x96000210
elr: 000000000005d6b4 lr : 000000000005dd0c (reloc)
elr: 000000007ff996b4 lr : 000000007ff99d0c
x0 : 000000007fa34fc3 x1 : 000000007fa34fc3
x2 : 00000000fffffffe x3 : 0000000000000020
x4 : 00000000ffffffff x5 : 0000000000000030
x6 : 000000007ffa8413 x7 : 000000000000000f
x8 : 00000000ffffffd0 x9 : 000000000000000c
x10: 0000000000000010 x11: 000000000000000c
x12: 0000000000000002 x13: 0000000000002150
x14: 00000000ffe3cd8c x15: 0000000000000008
x16: b0519d3b532f5bcb x17: 67effe077f86a67c
x18: 000000007fa3cdd8 x19: 000000007fa34fbb
x20: 0000000000000021 x21: 000000007fa357bd
x22: 0000000000000010 x23: 0000000000000000
x24: 0000000000000020 x25: 0000000000000000
x26: 00000000ffffffff x27: 000000007ffa86a8
x28: 000000007fa34fbb x29: 000000007fa34d60
Resetting CPU ...
### ERROR ### Please RESET the board ###
As tool is not accepting the change, tool is upgraded to 21.1
and 1)generated .sof and .jic file in 21.1 where data is not printing on tera term(boot failed)
2).sof (21.1) created .jic(18.1) with this we boot is successful.
  1. i) .sof (18.1) created .jic(18.1) boot = failed
  2. i) .sof (21.1) created .jic(21.1) boot = failed
iii).sof (21.1) created .jic(18.1) with this we boot is successful.
boot is successful but we are not able to use Signaltap nor transceiver tool kit!
queries:
1) In quartus prime pro 18.1 what can cause for not accepting the values ?(PFA)
2) .jic file created in 21.1 (followed procedure given in datasheet) but still boot failed.
3).sof (21.1) created .jic(18.1) with this we boot is successful.
    .jic with 21.1 is not booting, what can go wrong!
EBERLAZARE_I_Intel
How did you generate your Uboot files? Is this your own design? Is it based of the GHRD?
Rk_Athram
<How did you generate your Uboot files >
Two options are tried for u-boot
1. GHRD based. Taken from : https://releases.rocketboards.org/release/2020.05/gsrd/s10_gsrd/
"u-boot-spl-dtb.hex" is used to generate .jic
---> Working
2. Using rocketboards reference design provided. U-boot is built by following below instructions
git clone https://github.com/altera-opensource/u-boot-socfpga
cd u-boot-socfpga
git checkout -b test ACDS20.1_REL_GSRD_PR
make clean && make mrproper
make socfpga_stratix10_defconfig
make -j 24
The following files will be created in respective directories:
• $TOP_FOLDER/u-boot-socfpga/u-boot.img - U-Boot image file
• $TOP_FOLDER/u-boot-socfpga/spl/u-boot-spl-dtb.hex - SSBL/SPL hex file
---> This also works
With Quartus prime pro 18.1 version for .jic file generation
and .sof file for Quartus prime pro 21.1 version
For your information : uboot generation may not causing the issue,
as we used .sof from https://releases.rocketboards.org/release/2020.05/gsrd/s10_gsrd/
and created .jic using our .hex file with prime Quartus pro 18.1 version
--> this worked.
BUT the same tried with Quartus prime pro 21.1 version it is failing.
<Is this your own design?>
yes, customized according to our requirement
<Is it based of the GHRD?>
yes
Rk_Athram
created .jic with .sof  & .hex provided by GHRD in 21.1 boot is failing
created .jic with .sof  & .hex  provided by GHRD in 18.1 boot is successful
what is wrong in 21.1 tool ?
why .jic created in 21.1 is failing ?
Rk_Athram
Its been a  7 days, I am expecting solution for the issue i am facing
Rajesh
EBERLAZARE_I_Intel
If the 18.1 design is using Auto Upgrade to 21.1 in Quartus and is not working, then we do not recommend as such. We recommend that you stick to build your own design based of the version itself and not use the Auto Upgrade.
