idea
Hello
I need to turn on /of a led using de1 cyclone v then receive
which led is turnon in my terminal
How can I do this ? I dont have any idea which protocole can I use
I thought of serial communication ethernet using hps fpga or just using eclipse Nios II?
pleease help which simple solution can I do ?
THANK YOU.
Refer the following links that will help to you,
https://www.youtube.com/watch?v=2wuket4-q7q
Refer “Chapter 7 Examples for using both HPS SoC and FGPA” from DE1-SoC User manual
http://www.terasic.com.tw/cgi-bin/page/archive.pl?language=english&categoryno=165&no=836&partno=4
http://terasic.yubacollegecompsci.com/resources/de1-soc_control_panel.pdf
Best Regards
Vikas Jathar
(This message was posted on behalf of Intel Corporation)
Thank u alot.
Yeah I follow this Tuturial https://www.youtube.com/watch?v=2wuket4-q7q but there is a problem when I try to run Hello word in shell commend
:when I launch make
arm-linux-gnueabihf-gcc-static-g-wall -I/ip/altera/hps/altera_hps/hwlib/include -c main.c -o-main.o
process began :create Process<NULL, arm-linux-gnueabihf-gcc-static-g-wall -I/ip/altera/hps/altera_hps/hwlib/include -c main.c -o-main.o ---> failed
the error was : make <e=2> the system cannot find the file specified .
when I try to go to this folder hwlib/include is not exsist.
my quartus II is version lite 17.1. have it any relation with the version of quartusII ?
Hope you might able to resolve the issue which was you facing with the solution provided in thread,
https://www.alteraforum.com/forum/showthread.php?t=58760
Best Regards
Vikas Jathar
Intel Customer Support – Engineering
(Under Contract to Intel)
1-I resolve the problem I install a standard version quartus II I didn't get the same problem
but this version can t generate the file .sof
I dont have a licence file what can I do ?
2- I need to build a timer,I use hps-fpga how can I do this in qsys designer and program c ?
1. Standard version requires the license, what error occurred during .sof file generation? Can you provide screenshots?
2. For timer refer the thread,
https://www.alteraforum.com/forum/showthread.php?t=58791
Best Regards
Vikas Jathar
