21615 Discussions
jtag clock default configuration
sowmyasista
I had a small problem with the Jtag Clock . I have change the jtag clock to 6M
by the command jtagconfig --setparam 1 JtagClock =6M).The clock has got configured.But the problem is if i discard the jtag usb from the pc . I have to configure the clock again and again.
Do i have any alternate method so that i need not to configure the clock again . once after i configured even though i discard the jtag usb  from the pc.
Can any one help me out to solve this problem...
YuanLi_S_Intel
Hi, apologize that there is not way to that. You will need to execute the command to change the JTAG frequency
