I want to use latticemico8 core in cyclone chip,but I don't know how to use the source file and configure.the source files were downloaded.I need your help.thanks.
You cannot. Latticemico8 is for LatticeSemi products only.
我看见有一篇论文上说成功移植了lm8的处理器啊,只不过要修改一点代码,和配置,我不知道怎么改啊
even if you get the source code in vhdl or verilog, most probably they write it using mostly primitives for lattice fpga. you won't be able to use it for altera cyclone chip.
forget about it. if you want to use latticemico8, then you have to get lattice fpga. just like picoblaze for xilinx fpga. just find out about nios II if you want to use processor core on cyclone.- Mark as New
E.g. LatticeMico32 runs perfectly fine on Xilinx Spartan6 (check project called milkymist), so I believe it is easy to run it on Altera FPGA too.
