21615 Discussions
launch signal tap thru command line
I'm trying to open the siganl tap using the command line but fails.
I've found this link:
http://www.alteraforum.com/forum/showthread.php?t=40821
and tried using this command only:
open_session -name stp1.stp
I've put it in a tcl file and ran it in the command line using:
quartus_stp -t launch_stp.tcl
It does not work. When I run it, I get the following error, saying 'can't open signaltap II file for reading. Make sure the signaltap II file exists and has read permission".
Well, I checked, and the file do exists and has permission as any regular file. I've found this error documented here:
http://drlnet.dyndns.org/help/quartus/webhelp/mergedprojects/tafs/tafs/tcl_pkg_stp_ver_1.0_cmd_open_session.htm
But nothing special is said regarding that.
Any idea how to invoke the signal tap sw?
btw, I'm using version 10.1.
Thx.
Did you navigate to the correct directory? I would normally run it like this:
C:\Altera\quartus\bin\quartus_stp -t D:\test\test.tcl
