21341 Discussions
max v jtag resistors
I followed the app note for jtag with Max 7000S and it works perfect. I'm switching over to 5M40ZE64C5N, are the 10k and 1k resistor still required?
Also I'm switching from 5v with Max 7000S to 1.8v only for Max V, will there be any issue with JTAG ISP? I'm using USB Blaster.
thanks!
ok found the answer:
For MAX V devices, there are weak pull-up resistors for
TDI
and
TMS
, and pull-down
resistors for
TCK
. However, in a JTAG chain, there might be some devices that do not
have internal pull-up or pull-down resistors. In this case, Altera recommends pulling
the
TMS
pin high (through an external 10-k
resistor), and pulling
TCK
low (through an
external 1-k
resistor) during BST or in-system programmability (ISP) to prevent the
TAP controller from going into an unintended state. Pulling-up the
TDI
signal
externally for the MAX V device is optional.
