21489 Discussions
max10,is 10m04SAM153i7 compatible with10m04SCM153i7 ?
qd0090
hi everyone;
my product use  10m04SAM153i7.
since i have to wait a long time if i want to buy 10m04SAM153i7, i want to change it to 10m04SCM153i7.   that is   SA  => SC
the D4 of  the 10m04SCM153i7  should be connected to gnd
but now the pcb i left it NC
is that ok if i replace 10m04SAM153i7 by 10m04SCM153i7 ?
or should i have to change the pcb design
EngWei_O_Intel
Hi QD
Thanks for your request. If the new device you going to use required a GND connection, then you will need to modify the board. If it is the other way round, i.e. the new device required a NC, then you shall be fine:
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/rd03132006_933.html
Eng Wei
EngWei_O_Intel
Hi QD
Eng Wei
