Programmable Devices
20693 Discussions
modelsim library problem
hi. I am using quartusII 13.0 and modelsim. I built a library and a pachage file in it. I can use this library in quartus There is no error but When I try to compile project in modelsim there is two error. one of them is "Unknown expanded name." and other is "VHDL compiler exiting.". Is there somebody can help me??
Without the code/compile script and the actual error, we have no idea what the problem is.
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
library work;
use work.ornekler_paket.all;
this is my library definitions in quartus and there is no problem in quartus.
# ** Error: C:/Users/asuss/Desktop/fpga/ram_blogu/ram_blogu.vhd(5): Unknown expanded name.
# ** Error: C:/Users/asuss/Desktop/fpga/ram_blogu/ram_blogu.vhd(7): VHDL Compiler exiting
and this is the errors when I try to compile this code in modelsim.
I couldnt find what I am doing wrong. I cant find like this error in web.
It looks like you havent compiled the ornekler_paket file. Where is the compile script?
yes you are right the pachage must be compiled first. So much thank you for your help I tried to do this since 4-5 days but I couldnt think pachage must compile. Thank you very much again Mr. Tricky.
