Hi
I am trying to run a simulate in modelsim And I got those errors: # ** Error: C:/vhdl/modelsim/state maschine/Steer_Encoder.vhd(86): Actual (function call "conv_std_logic_vector") for formal "numer" is not a globally static expression. # ** Error: C:/vhdl/modelsim/state maschine/Steer_Encoder.vhd(87): Actual (function call "conv_std_logic_vector") for formal "denom" is not a globally static expression. # ** Error: C:/vhdl/modelsim/state maschine/Steer_Encoder.vhd(107): Actual (function call "conv_std_logic_vector") for formal "numer" is not a globally static expression. # ** Error: C:/vhdl/modelsim/state maschine/Steer_Encoder.vhd(108): Actual (function call "conv_std_logic_vector") for formal "denom" is not a globally static expression. I also found those possible solutions but didn't succeeded in implementing them 1. To change the case sensitive in the compiler "To fix this problem, edit the wrapper file and change the LPM parameters to lower case before compiling" 2. To create a library for the lpm component being used " creating simulation libraries Simulation libraries are required to simulate a design that contains an Altera primitive, LPM function, or Altera megafunction. Depending on your design, you must create the required simulation libraries and link them to your design correctly." Tanks in advanceLink Copied
It sounds like you're trying to call the conv_std_logic_vector function on a port map. You need a temporary signal to call the function then map the temporary signal to the lpm_divide port.
thanks
I added signals and made and called the conv function outside the component and that solved it. but now the compiler gives errors on the components with ports that connecting to signals in the fsm while some ports are external ports other are ports that connect between signals in the general code so the compiler won't recognize them. I can't leave them as open I can't ignore them and I can't insert them to themselves what should I do?- Mark as New
post your code.
entity fsm_tb is
end entity fsm_tb;
architecture arc_fsm_tb of fsm_tb is
--====================== fsm ports ===========================================
signal System_Clk_50MHz : std_logic:= '0'; --
signal System_N_Reset : std_logic:= '0'; --
signal FSM_enable_led : std_logic:= '0'; --
signal FSM_init_led : std_logic:= '0'; --
signal FSM_type_led : std_logic:= '0'; --
signal FSM_stop_led : std_logic:= '0'; --
--====================== communication ports ===========================================
signal UART_baud_sel : std_logic_vector(2 downto 0):= (others => '0'); --
signal UART_rx : std_logic:= '0'; --
signal UART_tx : std_logic:= '0'; --
signal led_sec : std_logic:= '0'; --
signal UART_rxerr_led : std_logic:= '0'; --
signal UART_txbusy : std_logic:= '0'; --
signal UART_rx_done : std_logic:= '0'; --
signal UART_dout : std_logic_vector(7 downto 0):= (others => '0'); --
signal UART_ready_tx : std_logic:= '0'; --
--====================== motion encoder ports ===========================================
signal M_E_done : std_logic:= '0'; --
signal M_E_DataIn : std_logic:= '0';--
--====================== steer encoder ports ===========================================
signal S_E_done : std_logic_vector (2 downto 0):= (others => '0'); --
signal S_E_DataIn : std_logic_vector (1 downto 0):= (others => '0'); --
--====================== motion pwm ports ===========================================
signal M_P_Pwm : std_logic:= '0'; --
--====================== steer pwm ports ===========================================
signal S_P_Pwm : std_logic:= '0';--
component Steer_Pwm is
generic (
DC: time:=17 ms; -- changeable
clock_period: time:=20 ns; -- changeable
max_pulse: time:= 1 ms; -- changeable
min_pulse: time:= 2 ms; -- changeable
neutral_pulse: time:= 1.5 ms -- changeable
port (
Rst : In std_logic; -- joined Rst to the FSM system
Clk : In std_logic; -- joined clock to the FSM system
Enable : in std_logic; -- Enable Steer motor
Pwm : Out std_logic; -- PWM pulse
pulse_length : in integer
end component Steer_Pwm;
component Motion_Pwm is
generic (
port (
Rst : In std_logic;
Clk : In std_logic;
end component Motion_Pwm;
component Steer_Encoder is
port (
done: out std_logic_vector (2 downto 0);
Rst: in std_logic;
Enable: in std_logic;
Clk: in std_logic;
DataIn: in std_logic_vector (1 downto 0);
angle: in integer;
slot_number: in integer;
spare: out integer;
turns_number: out integer;
res: in integer;
spare_flag: in std_logic;
turn_flag: in std_logic;
turn_pulse: in integer
end component Steer_Encoder;
component Motion_Encoder is
port (
done: out std_logic;
Rst: in std_logic;
Clk: in std_logic;
DataIn: in std_logic;
distance: in integer;
wheel_radius: in integer
end component Motion_Encoder;
component Communication is
generic ( ndbits : natural := 8);
port (
Clk : in std_logic;
Rst : in std_logic;
baud_sel : in std_logic_vector(2 downto 0);
rx : in std_logic;
tx : out std_logic;
led_sec : out std_logic;
rxerr_led : out std_logic;
txbusy : out std_logic;
rx_done : out std_logic;
dout : out std_logic_vector(7 downto 0);
ready_tx : in std_logic;
din : in std_logic_vector(7 downto 0)
end component Communication;
begin
test : entity work.fsm
generic map (
DC => 17 ms,
clock_period => 20 ns,
max_pulse => 1 ms,
min_pulse => 2 ms,
neutral_pulse => 1.5 ms
port map (
System_Clk_50MHz => System_Clk_50MHz,
System_N_Reset => System_N_Reset,
FSM_enable_led => FSM_enable_led,
FSM_init_led =>FSM_init_led,
FSM_type_led => FSM_type_led,
FSM_distance_value_led => FSM_distance_value_led,
FSM_stop_led =>FSM_stop_led,
FSM_angle_value_led => FSM_angle_value_led,
UART_baud_sel =>UART_baud_sel,
UART_rx => UART_rx,
UART_tx => UART_tx,
led_sec=> led_sec,
UART_rxerr_led => UART_rxerr_led,
UART_txbusy => UART_txbusy,
UART_rx_done=> UART_rx_done,
UART_dout=> UART_dout,
UART_ready_tx=> UART_ready_tx,
M_E_done=> M_E_done,
M_E_DataIn=> M_E_DataIn,
S_E_done => S_E_done,
S_E_DataIn => S_E_DataIn,
M_P_Pwm=> M_P_Pwm,
S_P_Pwm => S_P_Pwm
steer_pwm_comp: Steer_Pwm generic map (
DC => 17 ms,
clock_period => 20 ms,
max_pulse => 1 ms,
min_pulse => 2 ms,
port map (
Rst => System_N_Reset,
Clk => System_Clk_50MHz,
Enable => S_P_En,
Pwm => S_P_Pwm,
pulse_length => S_FSM_S_P_pulse_length
motion_pwm_comp:Motion_Pwm generic map (
DC => 17 ms,
max_pulse => 1 ms,
min_pulse => 2 ms,
port map (
Enable => M_P_En,
Pwm => M_P_Pwm,
pulse_length => S_FSM_M_P_pulse_length
Uart_comp:communication generic map (
ndbits => 8
port map (
baud_sel => UART_baud_sel,
rx => UART_rx,
tx => UART_tx,
led_sec => led_sec,
rx_done => UART_rx_done,
dout => UART_dout,
ready_tx => UART_ready_tx,
din => S_FSM_dout_reg
M_Encoder_comp:Motion_Encoder
port map (
done => S_M_E_done,
Enable => M_E_En,
DataIn => M_E_DataIn,
distance => S_FSM_distance,
slot_number => S_FSM_slot_number,
wheel_radius => S_FSM_Wheel_radius
S_Encoder_comp:Steer_Encoder
port map (
done => S_S_E_done,
Enable => S_E_En,
angle => S_FSM_angle,
spare => S_FSM_spare_angle,
turns_number => S_FSM_turns_number,
res => S_FSM_res,
spare_flag => S_FSM_spare_flag,
turn_pulse => S_FSM_turn_pulse,
turn_flag => S_FSM_turn_flag
System_Clk_50MHz <= not System_Clk_50MHz after 10 ns;
process
begin
wait until rising_edge(System_Clk_50MHz);
System_N_Reset <= '0';
System_N_Reset <= '1';
end process;
end architecture arc_fsm;
and please post the errors
Plus I also noticed you are asserting reset every 2 clock cycles. you need to wait at the end of the process or it will loop forever.- Mark as New
error sample
# ** Error: C:/vhdl/modelsim/state maschine/fsm_tb.vhd(253): (vcom-1136) Unknown identifier "s_m_e_done".# ** Error: C:/vhdl/modelsim/state maschine/fsm_tb.vhd(258): (vcom-1136) Unknown identifier "s_fsm_distance". those are signals that were defined at the fsm.vhd and enterd to the components ports- Mark as New
s_m_e_done and s_fsm_distance dont exist as signals in the testbench. you need to declare them at the top with all the other signals.
thanks it's working
I thought that we only define ports as signal when we make a test bench and the we ignore the other logic and signals in the code ... So I guess that if signals or constants are been used in a way that implement on other logic we need to define them as well like functions, components ...
