What is the error you are getting exactly? (Quartus normally tells you which line or what signal name has the multiple driver error)
the error is in the posedge clk for the counter. it says multiple constant driver error for counter, count_done and count_done1.
You are assigning those registers in two different processes.
These assignments should be made in a single 'always @' process, otherwise this would mean multiple drivers from the synthesizer's point of view.
