21615 Discussions
multiply two numbers
Hello.
I am a new to vhdl and as a part of my tranning i need to multiplay 2 numbers can u help me and tell my what i doing wrong?
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
use ieee.numeric_std.all;
ENTITY MUL IS PORT(
a,b: IN unsigned (3 downto 0);
y : OUT unsigned (7 downto 0));
END MUL ;
ARCHITECTURE Behavioral OF MUL IS
BEGIN
process (a,b)
variable temp1:unsigned(7 downto 0);
variable temp:unsigned(7 downto 0);
BEGIN
for j in 0 to 3 loop
if (b(j)='0') then
temp1:=(7 downto 0 =>'0');
else
temp1:=( j=>a(0),j+1=>a(1), j+2=>a(2),j+3=>a(3),others=>'0') ;
temp:=temp+temp1;
end if ;
end loop;
y<=temp;
end process;
END Behavioral;
whats wrong with
y <= a*b;
But if you need to build your own multuplier - you havent said what problems you are having with this code.
Yes i need to built my own multiplier my problem with the code is that logically i think it is ok and also compile but when i enter signals i am getting that y(out) is in unknown state..
Thx.
That means temp is unknown and probably temp1 aswell
Get a good testbench going in modelsim. This is debugging that you need to do yourself.
I am using a wrap program and active vhdl sim. so i dont need test banch can u see the code and maybe guide me why temp1 and temp getting an unknown state?
Thx.
because temp is never initialised.
And 'U' is not unknown, it is uninitialised. 'X' is unknown
Ok thx i will try to fix it thx.
I tried today this was not the issue but still thx .
--- Quote Start ---
--- Quote End ---
Are you referring to your original code? With Quartus synthesis, the missing initialization of temp is exactly the issue.
