Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
new to NIOS II. Need help for my requirement.
I am using Altera Arria V GX FPGA, 5AGXMA5G4F35C5N. I would like to run NIOS soft core in this FPGA.
I would like to have Ethernet 100MB and M.2 PCIe x 4 interfaces. I am hardware engineer hence I have no knowledge of NIOS, hence your inputs highly appreciated.
Does NIOS II support Ethernet 100MB and M.2 PCIe x 4 interfaces? What is the maximum ethernet speed I can achieve?
Is it possible to implement both MAC & PHY inside FPGA using NIOS?
See Altera's "triple-speed ethernet megacore function user guide (https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/ug/ug_ethernet.pdf)". This supports 10/100/1000-Mbps Ethernet. Note - this IP requires a license. This will give you the MAC but not the Phy. You'll need an external device to implement the Phy.
M.2 PCIe x 4? Arria V FPGAs support PCIe Gen2 x4 if that's what you mean. Refer to the "arria v avalon-mm interface for pcie solutions user guide (https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/ug/ug_a5_pcie_avmm.pdf)" for full details.
Cheers,
Alex
can any body help me.
i'm working with altera university program DE4 board, i'm using NIOS II to commande the transfer of data from FPGA to My SD_Card.
While building my projet within Eclipse this error appear.
need your help!!
Info: Linking TestSD.elf
nios2-elf-g++ -T'../TestSD_bsp//linker.x' -msys-crt0='../TestSD_bsp//obj/HAL/src/crt0.o' -msys-lib=hal_bsp -L../TestSD_bsp/ -Wl,-Map=TestSD.map -O0 -g -Wall -mno-hw-div -mhw-mul -mhw-mulx -mgpopt=global -o TestSD.elf obj/default/hello_world.o -lm -msys-lib=m
c:/intelfpga/17.1/nios2eds/bin/gnu/h-x86_64-mingw32/bin/../lib/gcc/nios2-elf/5.3.0/../../../../../H-x86_64-mingw32/nios2-elf/bin/ld.exe: TestSD.elf section `.text' will not fit in region `onchip_memory2_0'
c:/intelfpga/17.1/nios2eds/bin/gnu/h-x86_64-mingw32/bin/../lib/gcc/nios2-elf/5.3.0/../../../../../H-x86_64-mingw32/nios2-elf/bin/ld.exe: address 0x1d92c of TestSD.elf section `.rwdata' is not within region `onchip_memory2_0'
c:/intelfpga/17.1/nios2eds/bin/gnu/h-x86_64-mingw32/bin/../lib/gcc/nios2-elf/5.3.0/../../../../../H-x86_64-mingw32/nios2-elf/bin/ld.exe: address 0x1fd48 of TestSD.elf section `.bss' is not within region `onchip_memory2_0'
c:/intelfpga/17.1/nios2eds/bin/gnu/h-x86_64-mingw32/bin/../lib/gcc/nios2-elf/5.3.0/../../../../../H-x86_64-mingw32/nios2-elf/bin/ld.exe: region `onchip_memory2_0' overflowed by 93512 bytes
collect2.exe: error: ld returned 1 exit status
make: *** [TestSD.elf] Error 1
