20691 Discussions
on chip memory on system
i try use sram instead of on chip memory on system and my system has 3 components such as nios, jtag uart, sram. Help me!
Post something for us to look at...
--- Quote Start ---
--- Quote End ---
module main(
input CLOCK_50,
input [0:0] KEY,
inout [15:0] SRAM_DQ,
output [19:0] SRAM_ADDR,
output SRAM_UB_N,
output SRAM_LB_N,
output SRAM_WE_N,
output SRAM_CE_N,
output SRAM_OE_N
main_sys u0 (
.clk_clk (CLOCK_50), // clk.clk
.reset_reset_n (KEY), // reset.reset_n
.sram_0_external_interface_DQ (SRAM_DQ), // sram_0_external_interface.DQ
.sram_0_external_interface_ADDR (SRAM_ADDR), // .ADDR
.sram_0_external_interface_LB_N (SRAM_LB_N), // .LB_N
.sram_0_external_interface_UB_N (SRAM_UB_N), // .UB_N
.sram_0_external_interface_CE_N (SRAM_CE_N), // .CE_N
.sram_0_external_interface_OE_N (SRAM_OE_N), // .OE_N
.sram_0_external_interface_WE_N (SRAM_WE_N) // .WE_N
endmodule
when i load software on eclipse nios 2 to board, it has notification "verify failed between address 0x200000 and 0x205517" and then have windown "Downloading ELF Process failed".
Please help me. Thanks!
This is most likely to be a signal integrity issue. Has this hardware ever worked? Is this your own board? There's nothing wrong with the code you've posted.
Cheers,
Alex
I highly doubt Altera's got 2 megs of SRAM on-board, so it sounds like this is on a dev-board external to the FPGA. Read the documentation and make sure you adhere to the setup/hold times and all that. If you ARE using blockram or similar, note that most in- and outputs are registered, which adds to your delay. For example, reading a value from blockram with registered in- and outputs would take 2 clocks before you get the result.
DRAM is a whole different issue :-)
-Mux
