21602 Discussions
patch for telnetd in ~/apps
Hi all,
I have modified the Makefile of ~/apps/telnetd.
It is working fine.
you have to just change the makefile as give below:
The below is telnetd-Makefile modified version (modified by Goutam)
***# # configurable options# - set DEBUG = 1 to turn on debugging support#
DEBUG = 0
PROJ_NAME = telnetd
INSTALL_DIR = ~/rootfs
PROGS := $(PROJ_NAME)
CFLAGS += -O2
CROSS := nios2-linux-uclibc-
CC := $(CROSS)gcc
# # You should not need to modify anything beyond this point#
FLTFLAGS := -s 8192
CFLAGS += -DPARANOID_TTYS
-DTERMCAP
-DUSE_TERMIO
-DKLUDGELINEMODE
-D_GNU_SOURCE
OBJS = global.o logwtmp.o state.o telnetd.o termstat.o
authenc.o logout.o slc.o sys_term.o utility.o
all: $(PROGS)
$(PROJ_NAME): $(OBJS)
$(CC) -elf2flt="$(FLTFLAGS)" -o $@ $^
.PHONY: clean
clean:
-rm -f *.[oad] *.gdb $(PROJ_NAME)
.PHONY: install
install: all
ifeq "$(INSTALL_DIR)" ""
$(error No installation directory specified)
endif
mkdir -p $(INSTALL_DIR)/bin
install -v $(PROGS) $(INSTALL_DIR)/bin
hi:
why I run telned follow you guide,but failed, the failed information in telnet ternimal is:
login: incailid option -- t
BusyBox v1.1.1-pre <2006.05.18-01:52+000> multi-call binary
Usage: login [OPTION]...[username] [ENV=VAR ...]
Begin a new session on the system
