Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
pin migration 5CEA4, 5CEA5 and 5CEA7 in F484 package
Hi all,
just used an 5CEA4 in an F484, and wanted to upgrade to a bigger FPGA.
And noticed, that the bigger devices don't have the bank 2A at all.
How is this pin migration work, if a lot of the pins are not used at all in the bigger devices?
What am I missing, if I like to be able to use different devices in the same pinout?
Have you specified any migration parts in you Quartus project? Quartus allows you to specify a number of footprint compatible parts in a project and will check/route to a pinout suitable for all parts specified. You will still compile for a specific part. However, it'll ensure an appropriate pinout for use in any of them. I wouldn't worry about which banks each part does or doesn't have. Although that might be a problem it isn't necessarily so.
Cheers,
Alex
