Programmable Devices
20704 Discussions
prime ver 17 lite adition
i tried to run waveform simulation and inspire that in all sites i check posted that no licence needed for lite adition i get next error
"Unable to checkout a license. Vsim is closing.** Fatal: Invalid license environment. Application closing.
Unable to checkout a license. Make sure your license file environment variables are set correctly and then run 'lmutil lmdiag' to diagnose the problem.
Modelsim - Intel FPGA Edition uses the following environment variables to check the licenses (listed in the order of preference)
1. MGLS_LICENSE_FILE
2. LM_LICENSE_FILE. "
what i should to do in this case and how can i run waveform simulation?
Have you set “license.dat”?
If not, then refer following link for “Setting Windows Environment Variables” & then browse the license.dat file in “variable value box “,
https://www.altera.com/en_us/pdfs/literature/manual/quartus_install.pdf
Let me know if this has helped resolve the issue you are facing or if you need any further assistance.
Best Regards
Vikas Jathar
Intel Customer Support – Engineering
(Under Contract to Intel)
4.1.2.2 Licensing the Intel Quartus Prime Lite Edition and ModelSim - Intel FPGAStarter Edition SoftwareIntel offers the entry-level Intel Quartus Prime Lite Edition and ModelSim - Intel FPGAStarter Edition software. This software supports selected devices, provides limitedfeature support, and does not require license files.
i dont understand why i need any licence if i see this paragraph? and i steel not understand what to do!!!
--- Quote Start ---
--- Quote End ---
then i start run waveform simulation i get next error
2. LM_LICENSE_FILE.
i get licence file and put it in the bin64 folder but steel get this error.
what i need to do?
Error.
--- Quote Start ---
--- Quote End ---
Check the “Note” under “4.1.2.1 Licensing the Modelsim - Intel FPGA Edition Software” for ModelSim from the following link & refer previous post.
If you are using ModelSim-Intel FPGA Starter Edition Software then run-as administrator or Run the tool from installation directory itself instead running Modelsim from desktop short-cut.
Let me know if this has helped resolve the issue you are facing.
Best Regards
Vikas Jathar
