i tried to run waveform simulation and inspire that in all sites i check posted that no licence needed for lite adition i get next error
"Unable to checkout a license. Vsim is closing.** Fatal: Invalid license environment. Application closing. Unable to checkout a license. Make sure your license file environment variables are set correctly and then run 'lmutil lmdiag' to diagnose the problem. Modelsim - Intel FPGA Edition uses the following environment variables to check the licenses (listed in the order of preference) 1. MGLS_LICENSE_FILE 2. LM_LICENSE_FILE. " what i should to do in this case and how can i run waveform simulation?Link Copied
Have you set “license.dat”? If not, then refer following link for “Setting Windows Environment Variables” & then browse the license.dat file in “variable value box “, https://www.altera.com/en_us/pdfs/literature/manual/quartus_install.pdf Let me know if this has helped resolve the issue you are facing or if you need any further assistance. Best Regards Vikas Jathar Intel Customer Support – Engineering (Under Contract to Intel)- Mark as New
4.1.2.2 Licensing the Intel Quartus Prime Lite Edition and ModelSim - Intel FPGAStarter Edition SoftwareIntel offers the entry-level Intel Quartus Prime Lite Edition and ModelSim - Intel FPGAStarter Edition software. This software supports selected devices, provides limitedfeature support, and does not require license files.
i dont understand why i need any licence if i see this paragraph? and i steel not understand what to do!!!- Mark as New
--- Quote Start --- 4.1.2.2 Licensing the Intel Quartus Prime Lite Edition and ModelSim - Intel FPGAStarter Edition SoftwareIntel offers the entry-level Intel Quartus Prime Lite Edition and ModelSim - Intel FPGAStarter Edition software. This software supports selected devices, provides limitedfeature support, and does not require license files. i dont understand why i need any licence if i see this paragraph? and i steel not understand what to do!!! --- Quote End --- then i start run waveform simulation i get next error Unable to checkout a license. Vsim is closing. ** Fatal: Invalid license environment. Application closing. Unable to checkout a license. Make sure your license file environment variables are set correctly and then run 'lmutil lmdiag' to diagnose the problem. Modelsim - Intel FPGA Edition uses the following environment variables to check the licenses (listed in the order of preference) 1. MGLS_LICENSE_FILE 2. LM_LICENSE_FILE. i get licence file and put it in the bin64 folder but steel get this error. what i need to do? Error.
--- Quote Start --- i dont understand why i need any licence if i see this paragraph? and i steel not understand what to do!!! --- Quote End --- Check the “Note” under “4.1.2.1 Licensing the Modelsim - Intel FPGA Edition Software” for ModelSim from the following link & refer previous post. https://www.altera.com/en_us/pdfs/literature/manual/quartus_install.pdf If you are using ModelSim-Intel FPGA Starter Edition Software then run-as administrator or Run the tool from installation directory itself instead running Modelsim from desktop short-cut. Let me know if this has helped resolve the issue you are facing. Best Regards Vikas Jathar Intel Customer Support – Engineering (Under Contract to Intel
