I wish to know the sel function in megafunction of lpm_mux , is it edge trigger or level trigger ??
edge triggered if its registered, level triggered if its not.
do you mean that if quartus is registered then sel function is edge triggered ??
no, if you chose to put a pipeline delay in the mux, then the clock edge triggers the device. If you have no pipeline delay, then there is no clock so it is level triggered on select.
unless you're refering to voltages - do not concern yourself with voltage levels inside an FPGA device. Its all digital logic.
Thanks tricky your answer is greatly helpful !!
One more question if I choose put a pipeline delay in the mux , a clock input is created , can I short sel and clock together ? As I connect AD9481 to Cyclone III , It has a clock output , when rising edge indicate channel A is generated and when falling edge indicate channel B is generated .
no, thats not recommended.
The select line is sampled on the rising edge of the clock. So if sel = 0 then output = A, sel = 1 output = B.
if you tied clock and select together, on the rising edge of clock, select would also be changing, and so you would have no garantee of A or B - you might even make it go meta-stable. And another point - you can only use a single clock edge inside an FPGA- Mark as New
There is little info on lpm_mux in lpm.pdf....
Is it possible to use lpm_mux in pipeline mode to demultiplex a stream of 16-bit data @ 100MHz into two stream of 8-bit data @ 50MHz ? Can lpm_mux on the first rising edge of the clock select the first 8-bits out of 16-bits and on the second rising edge of the clock select the second 8-bits out of 16-bits and so on? I suppose that in this case Sel is ignored by lpm_mux?- Mark as New
No. lpm_mux uses a single clock mux. You'll have to do the demuxing yourself.
Sorry, I posted the wrong question ((
Here is what I meant to ask: Is it possible to use lpm_mux in pipeline mode to multiplex two stream of 8-bit data @ 50MHz each into a single stream of 8-bit data @ 100MHz ? Can lpm_mux on the first rising edge of the clock select the first 8-bit stream and on the second rising edge of the clock select the second 8-bit stream and so on? I suppose that in this case Sel is ignored by lpm_mux?- Mark as New
No. Its just a mux, Sel is always used and never ignored. You could easily do it though by having a toggle bit toggling at 2x data rate selecting the alternating halves of the wrod.
