21583 Discussions
problem with writing testbench
hi
I installed a qurtusii web edition included a modelsim 6.5
i've written a counter code in verilog and a simple testbench also.
when i compile the code in quartus there is no error but in modelsim when inputs change there is no change in output.
thank you
this is the code.
module counter4bit (
input clk,
input enable,
input reset,
output reg [3:0] outbits
reg [3:0] counter ;
always @ (posedge clk)
begin
if(enable == 1)
begin
if(reset == 1)
begin
counter <= 4'b0000;
end
else
begin
counter <= counter +1 ;
outbits <= counter ;
end
end
else
begin
outbits = counter ;
end
end
endmodule
module count_t () ;
reg resett, enablet,clkt ;
wire [3:0] out ;
counter4bit c1(
clkt,
enablet,
resett,
out
initial
begin
resett = 0 ;
clkt = 1 ;
enablet = 0 ;
# 10 enablet = 1 ;
end
always
# 20 clkt = ~clkt ;
endmodule
You are not resetting your counter to zero, which you must, because modelsim will start with counter set to 'UUUU'.
Also, note that in your module, the reset is synchronous and subject to the enable signal.
Thus, you need to have enable = 1 and reset = 1 long enough for count to reset to zero.
thank you rbugalho
