21615 Discussions
problem writing flash via alt_flash
I'm trying to store non-volatile data on my flash via
"alt_flash_open_dev", "alt_write_flash" etc.
but it doesn't work. One issue could be...
My flash is connected as a 8 Bit device, but if I read out the cfi-table it shows me that a 16 Bit device is connencted, therefore I have to use the
--width=8 extension when I flash the ram.
But how can I use the --width=8 extension in my NIOSII C++ programm, if it is possible at all???
Should I redesign the low level device driver???
Maestro
