21602 Discussions
quartus_pgm command to change divece
Wenxu
I have two device in my JTAG change, one is FPGA and another is a unknown device(it's a PHY) in my JTAG chain, and in GUI, I can click right button and change device to select the .bsdl file of the device, and then I can program .jic file for FPGA.
Now I want to use the script command to program FPGA, the normal command is
quartus_pgm –c usbblasterII –m jtag –o bpv;design.pof
but it said: JTAG chain contains unknown device.
I know how to solve this in GUI, but I don't know how to solve this by command.
Is there any command to change device with .bsdl file by command?
sstrell
You probably need to specify the device number in the chain.  Run jtagconfig to know which device is which.  https://www.intel.com/content/www/us/en/docs/programmable/683039/24-1/scripting-support-08828.html
NurAiman_M_Intel
Any update? Have you try to specify the device number in the chain?
AIman
Wenxu
I open a same case in IPS, and they help me to solve this problem as below:
1. add .bsdl file for unknown device in GUI
2. save all the setup in the GUI as a .cdf file
3. execute this cdf file in the quartus_pgm
Thanks & Best Regards
Wenxu
NurAiman_M_Intel
Thank you for sharing the solution in here. I am glad that you got help from IPS.
I will close this case for now.
Aiman
