20261 Discussions
"CONF_DONE pin failed to go high in device 1" - MAX 10 FPGA Dev
Vmuru2
 I am testing a design on MAX 10(10M16SAU169I7G) device with tool of quartus prime lite editon v16.0 and for programming ALTERA USB blaster rev.c is used
i am performing a single device configuration but when i initialize auto detect in the programmer it ask us to select either two device which are 10M16SA or 10M16SC. I selected 10M16SA regarding device used
Here .pof file is added to program or flash the device
 when i am trying to verify and program/configure. The configuration gets failed at 0% itself so i attached error message logs separately in screenshots for reference and attached schematic of JTAG connection with device.
Actually i probed all TMS, TCLK, TDI, TD0 which appears to be okay but when i am probed nstatus it appears to be toggling continuously.
i am little stuck at this moment so i need a suggestions to clear this error.
Thanks in advance
JohnT_Intel
May I know if you are able to configure sof file? Have you check that your boards is power up successfully?
Abe
Valued Contributor II
Max10 JTAG.PNGHave you connected the JTAG pins with correct Pull-up/PD resistor values.. 10K .. Check the Max10 confguration guide here : https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/ug_m10_config.pdf
 Please make sure you follow the pin connection guidelines mentioned here:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/dp/max-10/pcg-01018.pdf
The DEV_OE pin needs to be pulled low as well as the DEV_CLRn pin.
