21615 Discussions
"Internal Error: Sub-system: MLS, File: /quartus/synth/mls/mls_netlist.cpp" Error
Whenever I try to compile a design that I am currently working on, I always receive this error message:
"Internal Error: Sub-system: MLS, File: /quartus/synth/mls/mls_netlist.cpp, Line: 2016
cloned_sgate != 0
Stack Trace:
0x8bd44: MLS_ROOT::delete_mls_netlist + 0xb3e4
0xafee0: MLS_ROOT::clone_mls_netlist + 0x23840
0xb062f: MLS_ROOT::clone_mls_netlist + 0x23f8f
0x553db: MLS_INTERFACE::MLS_INTERFACE + 0x1762b
0x3a1c2: MLS_INTERFACE::get_ready + 0x4472
0x336d5: MLS_INTERFACE::~MLS_INTERFACE + 0x17345
0x3519a: MLS_INTERFACE::call_named_function + 0x82a
0x34f38: MLS_INTERFACE::call_named_function + 0x5c8
0x3c659: MLS_ROOT::start_from_mls_netlist + 0x49
0x613ef: scl_start + 0x5ba8f
0x656c3: scl_start + 0x5fd63
0x2e374: scl_start + 0x28a14
0x2ef1d: scl_start + 0x295bd
0x2f47f: scl_start + 0x29b1f
0x5475: scl_run_parallel_mls_script + 0xfd5
0x128ed: qexe_get_command_line + 0x206d
0x1573e: qexe_process_cmdline_arguments + 0x59e
0x15851: qexe_standard_main + 0xa1
0xa7f8: msg_exe_fini + 0x58
0xaf3c: msg_exe_fini + 0x79c
0x1f14: MEM_SEGMENT_INTERNAL::~MEM_SEGMENT_INTERNAL + 0x194
0xb8bf: msg_exe_main + 0x8f
0x159bc: BaseThreadInitThunk + 0xc
0x2a2e0: RtlUserThreadStart + 0x20
End-trace
Quartus II 64-Bit Version 13.1.0 Build 162 10/23/2013 SJ Web Edition"
From the message above, I believe that this is a netlist error, however I am not sure what is specifically causing a netlist error.
Has anyone ever encountered this message? Thank you.
