21615 Discussions
"std_logic_vector" is used but not declared
I worked with the book "Embedded SoPC Design..." from Chu and I have problem with my first (!) VHDL source code I typed from the book. I suppose this is very basic question - sorry about that.
The error I get: "std_logic_vector" is used but not declared ... but I thought, that is done by the use statement ....
library ieee; use ieee.std_logic_1164.all; entity eq1 is port( i0, i1: in std_logic; eq: out std_logic ); end eq1; architecture sop_arch of eq1 is signal p0, p1: std_logic; begin -- sum of two product terms eq <= p0 or p1; -- product terms p0 <= (not i0) and (not i1); p1 <= i0 and i1; end sop_arch; entity eq2 is port( a, b: in std_logic_vector(1 downto 0); aeqb: out std_logic ); end eq2; architecture struc_arch of eq2 is signal e0, e1: std_logic; begin -- instantiate two 1-bit comparators eq_bit0_unit: entity work.eq1(sop_arch) port map(i0=>a(0), i1=>b(0), eq=>e0); eq_bit1_unit: entity work.eq1(sop_arch) port map(i0=>a(1), i1=>b(1), eq=>e1); -- a and b are equal if individual bits are equal aeqb <= e0 and e1; end struc_arch;
--- Quote Start ---
--- Quote End ---
Your code has essentially two components in it. If you have multiple entities in a file, then you need the use statement above every entity declaration.
Cheers,
Dave
Thanks, that was it !
--- Quote Start ---
Cheers,
Dave
--- Quote End ---
