totally, in the module "vnp" there are 256(parameter N=256) "cnt"s to deal with.
every "cnt" should go through a "Cycle". One Cycle contains 3 steps. So the value of "Cycle" goes from 2'b00 to 2'b10 then retun 2'b00 like 00 01 10 00 01 10 00 01........ as the cnt grows 0 1 2 3...... that is
Cycle=0;
case(Cycle)
2'b00:
Cycle<=Cycle+1;
2'b01:
Cycle<=Cycle+1;
2'b10:
Cycle<=0;
cnt<=cnt+1;
endcase
following is the detailed code
always@(posedge Clk)
if(CNP_ON||!CE)begin
flag<=1;
Cycle<=0;
cnt<=0;
calc_a<=0;
calc_b<=0;
Mess_Buff_a<=0;
Mess_Buff_a<=0;
Mess_Buff_a<=0;
Mess_Buff_b<=0;
Mess_Buff_b<=0;
Mess_Buff_b<=0;
end
else
if(cnt==0&&flag==1)begin
cnt<=0;
flag<=0;
end
else
if(cnt==(N+1))begin
cnt<=0;//reset cnt
flag<=1;//reset flag
end
else
case(Cycle)
2'b00:begin
if(!cnt)begin
calc_a<={Mess_Din,Mess_Din,Mess_Din};
Mess_Buff_a<=Mess_Din;
end
else begin
calc_b<={Mess_Din,Mess_Din,Mess_Din};
Mess_Buff_b<=Mess_Din;
end
Cycle<=Cycle+1;
end
2'b01:begin //add SrcMem_Din in the second step
if(!cnt)begin
calc_a<=calc_a+{Mess_Din,Mess_Din,Mess_Din}
+{SrcMem_Din,SrcMem_Din,SrcMem_Din};
end
else begin
calc_b<=calc_b+{Mess_Din,Mess_Din,Mess_Din}
end
Cycle<=Cycle+1;
end
2'b10:begin
if(!cnt)begin
calc_a<=calc_a+{Mess_Din,Mess_Din,Mess_Din};
calc_b<=0;
end
else begin
calc_b<=calc_b+{Mess_Din,Mess_Din,Mess_Din};
calc_a<=0;
end
Cycle<=0;
cnt<=cnt+1;
end
endcase
in the simulation wave (in the attachment) at the red line cnt==0 flag==0 Cycle==0 so 2'b00 in case(Cycle) begin
if(!cnt)begin
end
else begin
end
Cycle<=Cycle+1;
but the simulation wave has a delay of one clock i have marked it out with yellow arrowhead as you see Mess_Buff_a[0]<=Mess_Din should be run when Cycle==2'b00 but it happens at Cycle==2'b01 the waveform of Cycle and cnt are right please explain thank you
(Virus scan in progress ...)
--- Quote Start --- as you see Mess_Buff_a[0]<=Mess_Din should be run when Cycle==2'b00 but it happens at Cycle==2'b01 --- Quote End --- It doesn't happen at Cycle == 1. Mess_Buff_a[0] is updated in the same clock cycle when Cycle is incremented from 0 to 1, as your code commands. This is how synchronous logic works.
--- Quote Start --- It doesn't happen at Cycle == 1. Mess_Buff_a[0] is updated in the same clock cycle when Cycle is incremented from 0 to 1, as your code commands. This is how synchronous logic works. --- Quote End --- thank you very much. I have misunderstanding the codes. the waveforms are right.
