sopc2dts
I am working on building up a new SD card image with slight modifications to the GHRD. I'm following the rocketboards example for generating a device tree (http://rocketboards.org/foswiki/documentation/gsrddevicetreegenerator). I'm getting the error message below using sopc2dts. Any thoughts as to why this is occuring. I've also tried it with the GHRD unmodified and gotten the same results.
~/cv_soc_devkit_ghrd$ sopc2dts --input soc_system.sopcinfo
> --output socfpga.dts
> --board soc_system_board_info.xml
> --board hps_clock_info.xml
Don't know how to parse hps_clock_info.xml
at sopc2dts.LogEntry.<init>(LogEntry.java:37)
at sopc2dts.Logger.logln(Logger.java:78)
at sopc2dts.Logger.logln(Logger.java:74)
at sopc2dts.parsers.BasicSystemLoader.loadSystem(BasicSystemLoader.java:55)
at Sopc2DTS.go(Sopc2DTS.java:182)
at Sopc2DTS.main(Sopc2DTS.java:80)
Loading of system failed.
at sopc2dts.parsers.BasicSystemLoader.loadSystem(BasicSystemLoader.java:59)
Thank you in advance.
I did it in a different way using the git repo :
git clone git://git.rocketboards.org/sopc-tools.git cd sopc-tools/sopc2dts make java -jar sopc2dts.jar -b <path/to/hps_clock_info.xml> -b <path/to/**_board_info.xml> -i <path/to/**.sopcinfo> -o socfpga.dts
Hope this helps !
