Programmable Devices
21600 Discussions
stratx IV configuration time reduction!!
HI
im looking to reduce configuration time in AS mode using SIVGX180 device & a serial flash. i cannot use CPLD or CPU for the configuration.
the problem is that altera states that the DCLK serial clock to the flash is between 17 & 40 Mhz. that leaves worst case scenario of 17Mhz & a conf. time that is too long.
is there a way to enter an external clock to the flash & FPGA? is there a way to ensure the 40Mhz clock?
is there another way for conf. without the use of MAXII or CPU?
THNX
