21335 Discussions
timing simulation
bonjour
I try for one day to do a simulation timing
The project is only a count16 write in VHDL
the RTL simulation is ok but in Gate Level Simulation every times are set to 0ps and waves are like a RTL simulation. (no delay between clock and outputs )
I forget something ...
I use Quartus10.1SP1 web edition with modelsim Altera starter 6.6d and the device is MAXII
can you help me?
thanks
are you running the gate level simulation yourself or with NativeLink? are you including the delay file (.sdo?) in your simulation?
I use NativeLink
effectively I don't include the delay file count16_vhd.sdo
how can I do?
I managed to include sdo file and everything works perfectly now.
I have much to learn ...
thank you
Pierre
