Programmable Devices
20704 Discussions
tx_bonding_clocks in ATX PLL and RapidIO IP Core
SYiwe
In my design I instantiate a 4X RapidIO Core and a ATX PLL IP Core. According to Table 12 in RapidIO user guide, I should connect the 24-bit tx_bonding_clocks of ATX PLL to tx_bonding_clocks_chN of RapidIO IP Core( where N=0~3) respectively.
But currently I can only generate a 6-bit tx_bonding_clocks in ATX PLL, and the signal definition of tx_bonding_clocks in XCVR PHY user guide is fixed 6-bit.
So I connect tx_bonding_clocks_ch0 of ATX PLL to tx_bonding_clocks_ch0~3 of RapidIO IP core, then I got timing analysis errors.
Any suggestion? How can I generate a ATX PLL IP core with 24-bit tx_bonding_clocks?
Thanks, regards.
CheePin_C_Intel
Hi Yiwen, I would like to apologize for the delay in response. It seems like I encounter some issues with notification reaching my mailbox. Sorry for the inconvenience. As I understand it, you have some inquiries related to the ATX PLL bonding clock connection to the rapidIO IP. For your information, each ATX PLL will have fixed 6 bit width for tx_bonding_clocks output bus. Since you are using a single ATX PLL to drive RapidIO x 4, you use the same ATX PLL 6 bit output bus to drive all the 4 RapidIO bonding clock input bus. Please let me know if there is any concern. Thank you. Best regards, Chee Pin
SYiwe
But according to the user guide, I should connect a 24-bit output ATX PLL to RapidIO x4.
Or should I use 4 ATX PLLs to drive RapidIO x4?
CheePin_C_Intel
For your information, the ATX PLL tx_bonding_clocks is only of 6 bits. You would not be able to get 24 bits output. There seems to be some confusion with the RapidIO user guide. Thus, if you are using one ATX PLL, then you would need to connect the same bus of ATX PLL bonding clocks to all the 4 RapidIO channels bonding clock bus. If you are using 4 ATX PLLs, then you can connect each PLL separately to each channel of RapidIO.
Chee Pin
CheePin_C_Intel
Just would like to follow up with you on this. Thank you.
SYiwe
Thank you for your answer.
Currently I use a single ATX_PLL, and how can I eliminate  the negative slacks in timing analysis in tx_bonding_clocks and rx_pma_clk clock region? (As you can see in the picture above).
I already set the tx_bonding_clocks , txclk and rxclk as global clock in assignment editor, the negative slack reduced to -0.371, still result in bit-error in data transmit and receive process.
I will be appreciated if you can give me some suggestions.
Thanks, regards.
CheePin_C_Intel
Thanks for your update. I understand that you are using a single ATX PLL and connect the bonding clocks per the guideline. However, you still observe some timing violation.
Would you mind to help duplicating a new case specific on the timing negative slack and let me know the new case number? I would like to further engage our timing expert to provide further assistance on the timing closure.
Chee Pin
CheePin_C_Intel
Just would like to check with you if you have managed to open a new case on the timing slack? Please feel free to let me know the case number. thank you.
CheePin_C_Intel
Thanks for your update. I understand that you have open a new case and one of my peer is currently working on it. I will set this case to close-pending for the moment and we shall continue to follow up with you in the new case.
Chee Pin
